Finding duplicate value and looping through each one to increment the value and make unique
  • Apr 29, 2021 11:45 AM UTC
  • 6 replies
  • 294 views
The problem:
We have duplicate ID's across various tables, an example being:
Table 1
ID 1 = UNI-ID1-234211
ID 2 = UNI-ID1-234211
Table 2
ID 1 = UNI-ID2-230011
ID 2 = UNI-ID2-230011
I want to find the duplicate ID's and then increment the last part of the ID, but retain first lowest value. For example:
Table 1
ID 2 = UNI-ID1-234212
Table 2
ID 2 = UNI-ID2-230012
ID 2 = UNI-ID2-230013
I've isolated the duplicates with a Matcher already. I've split the ID based on hyphen to get me 3 parts to the ID, _list{2} gives me the last part.
I assume I'll need to push it through a looping custom transformer maybe? or can it be done with Listing techniques too?
Thanks for your help,
Best answer by ebygomm
No need for looping, if you've already split the ID into a list, you can use a counter with the Counter Name (Group By) set to ID and starting from zero. Then you can use an attributecreator to add the count onto the third list item and recreate the id with hyphens
CaptureCapture1
Forum|alt.badge.img+54
  • Apr 29, 2021 12:19 PM UTC
CaptureCapture1
  • Apr 29, 2021 12:23 PM UTC
CaptureCapture1
Hey @ebygomm​ , what version of FME does the counter have a group by function? I'm using FME 2020.0.3.0 and there's no group by option there. Thank you for your answer though!
  • Apr 29, 2021 12:26 PM UTC
Your answer helped me solve it without the counter, I added a ListBuilder to group by my ID. Then ListExploder, and used the element counter to evaluate the last part of my ID. Thank you!
  • Apr 29, 2021 12:28 PM UTC
@ebygomm​  solution works, but for those who don't have a version of FME that has Group By on the Counter.
I essentially used a ListBuilder grouped by ID. Then ListExploder to get the element_count which can be added onto the last part of my ID.
The counter has always had a group by it's just not very well named. If you set an attribute for the Counter Name parameter, this will be a group by. I believe from 2021 this is now called Group ByCapture
  • Apr 29, 2021 12:30 PM UTC
As above, everyone has a version of FME that has a group by on the counter, even if it's not called Group By. Set the Counter Name to the attribute you want to group by
