Filter Date columns in file geodatabase
  • Jul 17, 2022 10:52 PM UTC
  • 90 views
fme_can_do_it
Forum|alt.badge.img+13
I am reading data from a file geodatabase in my workspace. The data is huge and takes time to process data. I have set up a query to only filter data that ends with .2022 but the workspaces are still slow.image
Therefore, I intend to set up a query on a Date Modified column and a Create date column in the file geodatabase. This will filter only data modified and created within the last seven days. I can't figure out how to set up a query and filter data from the last seven days in FME.
Any help and advice would be greatly appreciated.
Thank you,
Forum|alt.badge.img+54
  • Jul 19, 2022 10:04 AM UTC
Are you asking how to use a date query in a gdb reader?
fme_can_do_it
  • Jul 19, 2022 11:49 AM UTC
yes
  • Jul 19, 2022 12:20 PM UTC
So I'd probably do something like get FME to calculate the date 7 days ago, then use a featurereader to read the gdb and use something like this in the where clause
FORMAT(DATEMODIFIED, 'yyyyMMdd') >= @Value(last_7_days)
