FeatureWriter to postgres does not apply what he shows to you (Automatic vs Manual)
  • Jul 19, 2023 6:50 AM UTC
  • 51 views
ponceta
Forum|alt.badge.img+7
Here's a simple table creation process with FeatureReader and FeatureWriter
image.pngFor a value list table.
The structure is the same and provided from the source table
imageAutomatic Attribute definition
-> The primary key is not set
CREATE TABLE IF NOT EXISTS eau_potable.vl_polygones
    id integer,
    name character varying(200) COLLATE pg_catalog."default",
    color character varying(20) COLLATE pg_catalog."default",
    active boolean,
    CONSTRAINT vl_polygones_pkey PRIMARY KEY (id)
Manual Attribute definition (only manipulation is uncheck the automatic to manual)
-> The primary key is set successfuly
    id integer NOT NULL DEFAULT nextval('eau_potable.vl_polygones_id_seq'::regclass),
    active boolean,
This would be a nice thing to fix because I think everythink is known to FME (at least visually) to do its job as expected.
Remark : When using Dynamic (3rd option), you can make it work by specifying that you want id to be typed as serial and constrainted as Primary Key
FME(R) 2022.2.1.0 (20221202 - Build 22776 - WIN64)
itsmatt
Forum|alt.badge.img+48
  • Jul 19, 2023 2:13 PM UTC
Nice find - have you tested it in the latest FME 2023 version. It might already be fixed
