Extract triangles out of areas by angle?
  • Feb 29, 2016 12:32 PM UTC
  • 101 views
Hi!
I have a DWG-File with an area-layer, containing geometries and i want to seperate triangular areas (see Screenshot).
All geometries in the Screenshot are in the same layer. I tried to extract the triangular areas, but didn't find a way that works.
Facts:
- the triangles are not identical and have different areas (calculated by ExpressionCalculator) and different number of vertices (count by ExpressionEvaluator)
- all triangles have more than 3 vertices
So, I can't select these geometries with a Tester by area or number of Vertices...
Is there a way to calculate the angle of geometries or a another way to seperate these triangular areas?
Thanks for help!
Juli
  • Feb 29, 2016 12:36 PM UTC
Maybe you could try to generalize the geometries before counting the number of vertices? That could help getting rid of extraneous vertices.
pratap
Forum|alt.badge.img+12
  • Mar 1, 2016 5:36 AM UTC
Just a hint: Closed / Open polygons will make the difference...
Pratap
mark2atsafe
Forum|alt.badge.img+59
Hi @juli
I figure you should be able to find the triangles because they will have 3 (or fewer) interior angles <90 degrees. A rectangle would have more.
So... I created this workspace. You can download it with test data here:
https://www.dropbox.com/s/qumhpmagurj3km5/SpotTheTriangles.fmwt?dl=0
It seems to work well on spotting triangles, but also the occasional rectangle creeps through. I think it would depend on your source data. Here the data is building footprints, which are fairly rectangular (in fact I have to drop points out of a few to make triangles).
The angle test I actually set at 92 degrees. You might get better results by changing that - I can't decide whether up or down would work better. Probably upwards would filter out more rectangles (of one type) but let through different ones.
Anyway. I hope this helps
Mark
gio
Forum|alt.badge.img+15
  • Mar 3, 2016 1:44 PM UTC
@juli
If the triangles have areas they obviously are closed and are polygons, and have 4 or more vertices .
Not closed triangular polylines have four or more vertices but no area. (last vetex has same coordinates as first)
If a polygon boundary cannot be generalised to 4 vertices, they are not true triangles.
So to identify true triangles all you need to do is test for vertexcount = 4.
To test for "trianglishish" area's you could use this:
Tolerance to set triangle acceptence rate.
Works by the assumption that any triangle is 50% of the area of its oriented boundingbox. (try it out)
