Extract the Data
  • Oct 21, 2022 8:18 AM UTC
  • 44 views
asadamjad
Participant
Forum|alt.badge.img+12
anyone tell me how can i get the data I m using HHTPcaller how can I get the Columns
itsmatt
Forum|alt.badge.img+48
  • Oct 21, 2022 8:27 AM UTC
You'll need to add a little more information to your question. What does the response look like for the HttpCaller?
nielsgerrits
Forum|alt.badge.img+67
Your question is quite hard to answer without more context, but I suspect you will find the answer in the article Authenticating and Extracting Information from API calls with the HTTPCaller.
asadamjad
Participant
  • Participant
  • Oct 21, 2022 8:55 AM UTC
Thaks
fro this link
@nielsgerrits​
nielsgerrits
Careful, the client_secret is in this link and this is an open forum.
The response is JSON, see attachment. I can't help you because it is a data structure, not a table, so there are many pieces you can get from this in many different ways.
You can parse this using a JSON FeatureReader or do it manually using JSONFragmenters, JSONFlatteners and JSONExtractors.
A good start is Tutorial: Getting Started with JSON
