Extract Geometry as per Color
  • Jul 9, 2018 4:19 AM UTC
  • 7 replies
  • 135 views
parashari
Hi Experts, I am working with FME 2018.0. I have a set of roads as per the traffic congestion while red being the most, green being medium and blue being least congested. I have to extract the roads as per the color as below:
Out of red, green, blue- red. Only red is extracted out of red, green and blue.
Out of green, blue- green. Only green is extracted out of green and blue.
blue as it is.
I have tried using GeometryValidator, Intersector, but seems none of these are working. Any suggestions, advices
Best answer by takashi
In you screenshot, red, green, and blue seem to be separate three layers. If so, I think you can just read them as separate feature types. What do you need to extract?
  • Jul 9, 2018 6:28 AM UTC
parashari
  • Jul 9, 2018 8:36 AM UTC
Hi @takashi
Thanks for your support. Actually, I had a TIF data for that and I had to extract RGB on the basis of the above-mentioned criteria. I have attached the data below.
cleanimg.zip
parashari
  • Jul 11, 2018 10:43 AM UTC
@takashi
Did you try working on that?
  • Jul 11, 2018 11:26 AM UTC
What about this?
parashari
  • Jul 16, 2018 6:17 AM UTC
Exactly what is required! Thanks
parashari
  • Jul 18, 2018 4:54 AM UTC
What about this?
@takashi
Just one question in the color extraction part. So, if you take a look at the top left and mid-center (intersection part) these are a mixture of red and green (a bit of yellow) where the two lines intermediating. Could you please let me know what is the color code for that? And where can we find the code? Thanks. There is a problem attaching the file.
  • Jul 18, 2018 5:56 AM UTC
@takashi
Three primary color values for pure yellow is 255,255,0.
