ESRI Geodatabase (ArcSDE Geodb) The Product License has not been initialized.
  • Aug 15, 2018 2:40 PM UTC
  • 8 replies
  • 451 views
I made SDE connection through Arc Catalog to connect to geodatabase and when I used the reader ESRi geodatabase (Arc SDE), I chosed the created connection file of SDE.
When I tried to select the tables, I got the error as in the below image.
My Arc desktop is initialzed and the license server running.
I installed also oracle client to make the connection file because DB in Oracle.
  • Aug 15, 2018 3:09 PM UTC
Which license have you activated in the ArcGIS Administrator?
  • Aug 16, 2018 8:23 AM UTC
Advanced Concurrent use
  • Aug 16, 2018 8:28 AM UTC
Which version of FME are you running? 32-bit or 64-bit?
Is the database client a 32-bit or 64-bit version?
What happens if you do the following:
  • Open ArcCatalog
  • Open the Python interpreter from Geoprocessing / Python
  • Type "import arcpy" and hit enter
Any errors or unexpected messages?
  • Aug 16, 2018 1:35 PM UTC
  • Open ArcCatalog
Database client is a 64-bit.
If I do the previous scenario, at the second step the application is closed.
  • Aug 16, 2018 1:41 PM UTC
Have you installed and licensed the ArcGIS 64-bit Background Geoprocessing module?
It's very important that you verify that you've got all the prerequistes right:
https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
In short:
  • If you're running 32-bit FME, you need a 32-bit ArcGIS client e.g. ArcGIS Desktop and a 32-bit database driver
  • If you're running 64-bit FME, you need a 64-bit ArcGIS library e.g. ArcGIS Server or the 64-bit Background Geoprocessing and a 64-bit database driver
Any other combination won't work.
  • Sep 26, 2019 3:30 PM UTC
Today I face the same issue. Does anyone have a suggestion for solution?
nielsgerrits
Forum|alt.badge.img+67
Do you use ArcGIS Pro? I found I need to start Pro if I can't get get an ESRI license related error.
rudy_v
  • Nov 7, 2019 5:19 AM UTC
If you are using 64-bit FME, you need the following:
Background Geoprocessing (64-bit) - ArcGIS need to be installed first or
ArcGIS Pro installed
We are using ArcGIs Pro 2.4 on our PC and FME Server and it works fine connecting to GeoDatabase. Don't have ArcGIs installed
Note also: Each user licensing need to be set for Pro, as it works on user level login, and ArcGIS work on PC level licensing
