Emailer issues FME 2020.1
  • Oct 9, 2020 12:59 PM UTC
  • 59 views
gboquin
Forum|alt.badge.img+8
Hello FMEr's around the world!
I am having an issue with the emailer in 2020. its rejecting the email for no reason that I can understand.
Below is a portion of the log and a picture of the error.
Thanks in advanced for any feedback. Stay safe!
G
Feature Type: `FEATURE_TYPE'
Attribute(32 bit unsigned integer): `_creation_instance' has value `0'
Attribute(string) : `fme_feature_type' has value `Creator'
Attribute(string) : `fme_geometry' has value `fme_undefined'
Attribute(encoded: UTF-8) : `fme_rejection_code' has value `ERROR_DURING_PROCESSING'
Attribute(encoded: UTF-8) : `fme_rejection_message' has value `<class 'OSError'>: [WinError 10013] An attempt was made to access a socket in a way forbidden by its access permissions'
Attribute(string) : `fme_type' has value `fme_no_geom'
Coordinate System: `'
Geometry Type: IFMENull
EmailerError
  • Oct 9, 2020 1:03 PM UTC
The error points to the port already being in use, which is a bit strange.
Can you share a screenshot of the Emailer properties?
gboquin
  • Oct 9, 2020 1:15 PM UTC
Thanks for the quick response.
Unfortunately I cant as it contains sensitive information. I am guessing that my company has passed some security patches that has removed my permissions to that port.
