DGN (v7) Reader - FME reads a strange geometry (FME 2018.1)
  • Sep 18, 2020 12:12 PM UTC
  • 101 views
oscard
Forum|alt.badge.img+23
I'm facing a strange issue reading a DGN file with FME 2018.1. If I open it with the Data Inspector, I see a weird aggregate whose origin I do not understand:
dgn_strange_geom
If I open the file with a DGN viewer or AutoCAD, I dont't see anything wrong:
dgn_ok_geom
I use the default parameters of the DGN (v7) Reader. I have tried to change some of them to see what happens, but so far no luck.
Does anyone know why FME builds such a weird a geometry? Is there any workaround?
I have tested the same DGN with the last version of FME and everything looks fine, but right now the client doesn't want to upgrade from the 2018 version.
Obviously, something has improved over the last couple of years to let FME read this DGN properly. I have been reading the "Change Logs", but I can't find the improvement that could have allowed the reader to form the proper geometry.
It would be a great help if someone could lead me to the improvement of the reader. Maybe that way I can understand what is wrong with my DGN file.
Thanks for any help provided!
xilef
Forum|alt.badge.img+5
  • Sep 21, 2020 5:35 PM UTC
Hi @oscard​ , are you able to share a sample of data? I wonder if this could be related to the insertion point of these features. If you take a look at the features' coordinates, do they reference the point where they all see to be linked to?
oscard
  • Sep 22, 2020 5:41 AM UTC
I can't share the DGN, but I will try to check what you have told me. Thanks!
oscard
  • Oct 13, 2020 8:43 AM UTC
It seems the issue was that several complex shapes had the same header (whatever that is in a DGN file). It has been solved, but it would be great if FME could detect such things and write a warning in the log. Finding the root of the issue has been a pain.
