CSV - update column value with a 0
  • Jul 26, 2021 6:22 PM UTC
  • 5 replies
  • 94 views
zentnerfabian
Forum|alt.badge.img+5
Hey guys,
I have an CSV file where I have 4 different columns with values (column1 till column4). I'am creating in the attribute manager a new columns (column5) where I connect all the values of the first four columns with a point in between.
For example
column1, column2, column3, column4, column5
1, 2, 3, 4, 1.2.3.4
`column2` has the special that there are numbers from `1` til `99`. I want to put infront all values of `column2` which are from `1` til `9` a `0`, so that it looks like the example. But already two digits numbers should not get a `0`.
For example
1, 02, 3, 4, 1.02.3.4
3, 65, 5, 9, 3.65.5.9
How can I manage this? Has anybody a clue? Or could somebody help me please?
Thanks in advance!
Have a good day!
Cheers,
Fabian
Best answer by hkingsbury
Hi Fabian, you can use the StringFormatter before the AttributeManager. Have the format string as '02d'
hkingsbury
Forum|alt.badge.img+73
  • Jul 26, 2021 8:09 PM UTC
zentnerfabian
  • Jul 27, 2021 3:43 AM UTC
Hi hkingsbury,
thank you for your answer. I will try it today!
geomancer
Forum|alt.badge.img+71
  • Jul 27, 2021 8:32 AM UTC
Alternatively you can use @PadLeft when defining column5 in the AttributeManager.
@Value(column1).@PadLeft(@Value(column2),2,0).@Value(column3).@Value(column4)
zentnerfabian
  • Jul 27, 2021 2:46 PM UTC
@hkingsbury​ it works really well! thanks a lot!
zentnerfabian
thank you @geomancer​ this option worked also!
