Create grid from polygones with equally divided four sides
  • March 23, 2021
  • 5 replies
  • 104 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I have a set of polygones, each having 4 sides (right figure)
Each pair of facing sides are divided into equal segments. Is there a way somehow to make a grid for each polygone by linking facing vertices as depicted in the left figure ?
Screenshot 2021-03-24 222721Thank you in advance.
itsmatt
Forum|alt.badge.img+48
  • March 23, 2021
Hmm, can you provide a bit more info? I'm not sure I fully understand​
lianaolianov
  • March 24, 2021
Hello,
I updated the post with a figure. I hope that it is clearer now.
Thank you for your interest.
DanAtSafe
Forum|alt.badge.img+23
  • March 25, 2021
Hello,
@lianaolianov​ Do the input polygons already have facing vertices to be linked or only 5 coordinates at the corners?
DanAtSafe
  • March 25, 2021
Hi @lianaolianov​ Try the attached workspace. It assumes that the shorter sides will be split in half and there is a prompt for the division of the longer sides.
mark2atsafe
Forum|alt.badge.img+59
  • March 26, 2021
I posted an answer to this as our question-of-the-week here: https://community.safe.com/s/question/0D54Q00008X5XOtSAN/question-of-the-week-replacing-rotated-features-with-a-grid
I hope it helps to solve the problem.
