Counter generating corrupt values
  • Sep 21, 2020 9:56 AM UTC
  • 5 replies
  • 105 views
robinb
Hello,
I have an FME Desktop workflow within which I have a Counter that is set to start at 700,000, but the final three entries are not rendering with a correct value as per the attached screenshot.
The Counter scope is local and I do have a second Counter within this workflow that works fine, although I was having this prior to introducing the second Counter (this has a different transformer name, is also local and starts from 1).
I have run this workflow a few times now with Feature Caching On and Off, plus have closed all other FME sessions, but am still getting the issue.
Has anyone experienced this before?
Thanks,
RB
Best answer by ebygomm
Can you try inserting a python caller (doing nothing) before your Counter, it might be a feature table issue. Inserting the python caller will break the feature tables
Forum|alt.badge.img+54
  • Sep 21, 2020 10:49 AM UTC
robinb
  • Sep 21, 2020 11:51 AM UTC
Thanks @ebygomm​ that has solved the issue
mark2atsafe
Forum|alt.badge.img+59
What version of FME are you using? This issue is reported fixed in 2019.2.3 and 2020.0 (FMEENGINE-61413), so if you are getting the problem in a newer build I'd like to let the developers know.
robinb
  • Sep 22, 2020 3:44 PM UTC
I'm using 2019.2.0.0 so panic over :0
mark2atsafe
Excellent. Thanks for letting me know.
