Could anyone help me ,I am trying to read the shape zip file which contains shp,dbf,prj,shx files inside it , so the filename is "az_maricopa.shp.zip" which is of the size 975.8 MB in the fme server, so i am getting an error like this:
  • Apr 25, 2023 12:32 PM UTC
  • 47 views
kailinatsafe
Forum|alt.badge.img+24
Hello @gowripriya2k​, thanks for posting! Are you able to read the same shapefile into FME Form? Does it also cause an error? Otherwise, it might be helpful to know what version of FME Form and Flow you're using? If you're able to share the problematic shapefile, that would be awesome! Best, Kailin.
