Correct WKT but still rejected by the geometry replacer
  • Jun 6, 2022 8:20 AM UTC
  • 209 views
michiedem
Forum|alt.badge.img+7
I am running into something I have not ran into before: I have an XML_fragement attribute with a WKT. For example (direct copy): POINT (154791.869730325 463171.926750512)
When I use the geometry replacer, set to WKT, I get a rejected feature: INVALID_PARAMETER_GEOMETRY_SOURCE
When I use an attribute creator, than manually paste the value (POINT (154791.869730325 463171.926750512)) and connect the geometry replacer to the new attribute it works flawlessly. Also when I try the featuremerger and merge on 'new atribute' and 'xml_fragement', nothing merges/matches.
Why? They are exactly the same values (ctrl c + ctrl v), there is also no space or enter at the end of the value.
FME Desktop 2022.1
ctredinnick
Forum|alt.badge.img+22
  • Jun 6, 2022 9:43 AM UTC
If the feature merger isn't merging (on the original value, compared to the copy/pasted POINT (154791.869730325 463171.926750512)), then they're not the same value. They may look the same, but something about it has changed. That, or it's the wrong xml value.
You could try a string searcher/string replacer, to see if there's any character which isn't meant to be. Regex like [^[:alnum:]] will find anything which isn't alphanumeric, or [^[:alnum:] .()] to search for or replace anything you wouldn't expect to be there.
Also, turns out you can safely add a space or enter at the end of a wkt and the geometry replacer still works fine.
michiedem
  • Jun 6, 2022 10:20 AM UTC
I am sure it's the right xml-value. I tried the stringsearcher, but I still can not find a difference between the two attributes.
https://repository.overheid.nl/sru?query=c.product-area==%22lokalebekendmakingen%22%20AND%20w.locatiepunt%20within/rijksdriehoek%20%22155000%20463000%200.3000%22
Then: XML fragmenter on "geometrie".
Forum|alt.badge.img+54
  • Jun 6, 2022 10:29 AM UTC
The process works for me (XML Fragmenter followed by geometry replacer) in an older version of FME
