Convert value into new column.
  • Nov 10, 2022 6:23 PM UTC
  • 6 replies
  • 153 views
mr_fme
Forum|alt.badge.img+9
I need to transform the value of this column and a new column...the values are always the same.
captura
Thank´s
dustin
Forum|alt.badge.img+36
  • Nov 10, 2022 7:26 PM UTC
If I'm understanding correctly, I believe you can use a BulkAttributeRenamer with the parameter shown in the screenshot.
mr_fme
  • Nov 10, 2022 7:47 PM UTC
No, sorry. I was updated the post. It´s better to understand.
mirco
  • Nov 11, 2022 6:56 AM UTC
Do you mean something like this:
Create a new attribute named with the value of anoher attribute:
lifalin2016
Forum|alt.badge.img+42
  • Nov 11, 2022 9:32 AM UTC
You may be looking for AttributePivoter, that performs a grouping of values in a single column, and aggregates the other values.
mr_fme
  • Nov 11, 2022 12:16 PM UTC
Very good!
But the new attribute created don´t exposed automatically. It´s a problem.
hkingsbury
Forum|alt.badge.img+73
  • Nov 14, 2022 7:08 PM UTC
Very good!
This is stepping into dynamic workflows/schemas. You now need to create a schema feature with the correct schema and change your writer to accept a schema feature. Ofcourse, if you're wanting to use FME transformers after setting that new field it becomes problematic, but there are ways around it depending what you're wanting to achieve
https://community.safe.com/s/article/dynamic-workflow-tutorial-introduction
https://community.safe.com/s/article/dynamic-workflows-advanced-example-modifying-the-s
