Control the workflow
  • Feb 18, 2022 10:59 AM UTC
  • 57 views
fme_hans
Is the following possible?
An FME workspace writes to a table. After the writers are ready I want that process to continue with other transformers and an other writer which must be writing last. I don't want to create 2 workspaces.
  • Feb 18, 2022 11:04 AM UTC
Look into using multiple FeatureWriter transformers, rather than the "classic" writers. You can chain them together to get the desired workflow.
nielsgerrits
Forum|alt.badge.img+67
Use FeatureWriters instead of Writers. These have a summary outputport. Connect a Sampler to the summary outputports, set the sampler to last 1 feature, and use that for following transformers and FeatureReaders.
fme_hans
  • Feb 20, 2022 11:39 AM UTC
Multiple Featurewriters all connected to a FeartureHolder via Summary seems to work. Thanks for the tips.
