Coincident vertices - how to find non coincident vertices
  • Aug 29, 2022 2:58 PM UTC
  • 51 views
I have two line shape files. File 1 is the duct layer and file 2 is cable layer. When cable layer is drawn on duct, cable vertices must be coincident ( snap) to duct vertices. How to find the cable vertices that are not coincident with duct?
Thank you for the help
  • Aug 29, 2022 3:33 PM UTC
One possible solution could be to break the lines into points (Chopper with max vertices = 1) and then use the AnchoredSnapper to try and snap the two files. The vertices that exit the Untouched are not coincident according the defined snapping distance.
