Check displacement between geometries
  • May 11, 2023 5:06 PM UTC
  • 71 views
mr_fme
Forum|alt.badge.img+9
How can I check if two equal or similar geometries are displacement in some way when they overlap? I don't want to validate when they are not related in any way, but only if they are with some kind of displacement.
Thanks
Best answer by itsmatt
Do the features have IDs? If you you can use a CenterPointrRplacer followed by a NeigborFinder to get the direction and offset distance (you can use the ID to group-by in the NeigborFinder
itsmatt
Forum|alt.badge.img+48
  • May 12, 2023 8:42 AM UTC
mr_fme
  • May 12, 2023 2:44 PM UTC
I have ID but are differents...Are two dataset with similar features or equals and ID differents between them.
itsmatt
  • May 15, 2023 6:37 AM UTC
ok, depending on the rest of the data the NeighborFinder might still work. You can set it up so there it only matches with the closest feature. I'd give it a go.
