ChangeDetector Check Geometry vs Shape
  • Aug 10, 2021 6:17 PM UTC
  • 140 views
dkirouac
Forum|alt.badge.img+5
If I Check Geometry in the ChangeDetector does comparing Shape in the Check Attributes do anything additional or are the Shape attributes compared as part of the Check Geometry?
Thanks,
David
jkr_wrk
Forum|alt.badge.img+37
  • Aug 11, 2021 7:23 AM UTC
When I create 2 points and connect them to a ChangeDetector I can not select the Shape attribute. This means that your Shape attribute probably contains a text or binary version of the Geometry. Checking this attribute in the Check Attributes will do a binary or text comparison. This for example means that LINESTRING(5 1,6 1) will not match LINESTRING(6 1,5 1) but Check geometry with Lenient Geometry Matching set to Yes will match as unchanged. So I would recommend to detect changes on the geometry and not on the text/binary version of the geometry. You can see the contents of the Shape attribute if you connect an Inspector to the Transformer (or prior Transformer).
dkirouac
  • Aug 11, 2021 5:37 PM UTC
Thank you. I could not find an explanation in the documentation.
