Change "igds_cell_name" value ??
  • Jul 7, 2023 3:02 PM UTC
  • 69 views
Hello everyone,
I am currently working with .DGN files.
My goal is to create a new DGN file with new values in the "igds_cell_name" field.
I would like to know if it is possible to modify the "igds_cell_name" attribute value???
Because at the moment,
itsmatt
Forum|alt.badge.img+48
  • Jul 10, 2023 8:43 AM UTC
You can read more about how FME treats DGN cells here: https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/igds/Cells.htm - It also looks like there is a basic tutorial/example here: https://community.safe.com/s/article/writing-dgn-cells-workspace
My take away is that you can definitely rename the attribute but I think FME will look for an existing cell in the output dgn template file to use.
As far as I can tell you can't use FME to create new cells or to rename existing cells in a dgn file.
Disclaimer - I don't work with DGN much and have not tested the workflow.
