Can we set a condition to only run a reader based on the results from another reader?
  • Dec 9, 2021 9:49 PM UTC
  • 5 replies
  • 83 views
benvk
Forum|alt.badge.img+8
I have a workbench that has two ESRI Geodatabase (ArcSDE GeoDB) readers. The first (TableA) is a table containing updates that have been made, there could be up to 500 rows found.
The other (TableB) is the table that needs to be manipulated based on the updates found in TableA, this table has 500,000 rows.
For efficiency sake, I am hoping to only read the TableB if there are rows returned from TableA. Can we tell the workbench to run the TableA reader first, IF rows found in TableA, then read TableB and continue through workbench processes, ELSE end workbench.
Any thoughts on if this is a possibility?
Best answer by gazza
Use a FeatureReader to read in the second table rather than a regular reader and you can control it with the output from the first reader.
gazza
  • Dec 9, 2021 10:12 PM UTC
hkingsbury
Forum|alt.badge.img+73
  • Dec 9, 2021 11:31 PM UTC
Have a look here re comparisons of the two
https://community.safe.com/s/question/0D74Q000008sD75/detail?s1oid=00D30000000ePES&s1nid=0DB0c000000Gmzx&emkind=chatterCommentNotification&s1uid=0054Q00000EwvQs&emtm=1639003549101&fromEmail=1&s1ext=0
benvk
  • Dec 10, 2021 12:56 AM UTC
Thanks for the replies, that's exactly what I needed to do.
This will drastically reduce run time on the majority of executions as it is only every other week that there will be updates needing actioning!
Thanks
benvk
  • Dec 10, 2021 1:31 AM UTC
@Gary Nicholson​, Just thinking this through, if my first TableA returns 10 entries, wont this trigger a read of TableB 10 times?
I am thinking I will need to add a sampler to only allow the first feature found to pass through to initiate the Feature Reader?
gazza
  • Dec 10, 2021 1:35 AM UTC
It depends on what you are reading in from TableB. If you want to read in the entire TableB then yeah, a sampler will allow you to only read it in once. If you are using the output from TableA to just read in one record from TableB at a time then you will want all ten features to flow through.
