can we retrieve data from a cloud with fme?
  • May 23, 2023 12:25 PM UTC
  • 57 views
solene01
Forum|alt.badge.img+3
I would like to update my database with an excel file the problem is that it is on a cloud. This is a doc itself updated by several partners. Is it possible with fme to recover this data?
Thank you in advance for your help
hkingsbury
Forum|alt.badge.img+73
  • May 23, 2023 8:05 PM UTC
Short answer yes, to give a longer answer, we need some more details:
  • Where is it stored? O365, Dropbox, GDrive?
  • Do you have access?
  • Is it just new rows being added? or does the schema change?
solene01
  • May 25, 2023 9:21 AM UTC
Think of your help:
- it is stored on NFS,
- yes I can request access
- yes the diagram doesn't change it’s just to add lines
Forum|alt.badge.img+63
Think of your help:
Just to clarify, NFS is Cloudian, right? It appears to be S3 compatible so maybe the regular S3 options within FME would already do the trick. Otherwise I'm sure they'll have an API so you can use an HTTPCaller to download the file and process it.
solene01
  • Jun 5, 2023 12:26 PM UTC
Good morning,
Thanks for the information indeed the support gave me the tool.
thank you
