Can the FME workspace be published on the FME server when the build is different?
  • Nov 30, 2022 4:32 PM UTC
  • 32 views
fme_can_do_it
Forum|alt.badge.img+13
I am currently running FME Server 2022.0.0.2 Build 22343 and FME Desktop 2022.0.1.0 Build 22346. My question is whether it is safe to keep the FME server at its current build version. Would it be better to upgrade the FME server to the same version as the FME desktop? It would be greatly appreciated if you could assist with this.
nielsgerrits
Forum|alt.badge.img+67
Not sure with such a minor difference, but in general you should keep server and desktop on the same version, or server newer than desktop, and not the other way around.
