Can't read geopackage that is inside a downloaded zip file inside a folder created by TempPathnameCreator
  • Sep 13, 2023 5:56 PM UTC
  • 5 replies
  • 290 views
essb
Hi
Been struggling with this for the last hours now and I cant get it to work with gpkg, with shp it works fine. But this file i need to download is gpkg.
The data is open road data and the zip is around 2.7Gb big.
This is the error I get
OGCGEOPACKAGE reader: Dataset 'C:\\FME_TEMP\\wbrun_1694624249590_18024\\fmetmp_0\\1694627133694_13812_d\\tor050\\http_download_1694627134354_13812.zip.gpkg' requires file extension '.gpkg'. Using dataset 'C:\\FME_TEMP\\wbrun_1694624249590_18024\\fmetmp_0\\1694627133694_13812_d\\tor050\\http_download_1694627134354_13812.zip.gpkg.gpkg'
OGCGEOPACKAGE reader: C:\\FME_TEMP\\wbrun_1694624249590_18024\\fmetmp_0\\1694627133694_13812_d\\tor050\\http_download_1694627134354_13812.zip.gpkg: No such file or directory
OGCGEOPACKAGE reader: Failed to open the dataset 'C:\\FME_TEMP\\wbrun_1694624249590_18024\\fmetmp_0\\1694627133694_13812_d\\tor050\\http_download_1694627134354_13812.zip.gpkg'. Please ensure source data is valid and correct
reader is selected
I added the workspace so you can try to find out what is wrong, maybe its a bug of some sort.
EDIT: Seems FME cant read a zipped 6Gb gpkg. Luckily for me they offer the material as shapefiles aswell. Its a big zip file consisting of 19 subfolders (municipalities) and each folder has a shapefile with the data i need. So Iam now using the same setup with temppathnamecreator and featurereader, but instead of gpkg iam using shape. And it works! :)
nielsgerrits
Forum|alt.badge.img+67
Does it work with a smaller geopackage?
Can u unzip it using the ZipExtractor custom transformer?
essb
  • Sep 13, 2023 6:13 PM UTC
I tried with other smaller files and it works. So maybe the problem is that the file is to big?
Forgot to mention, Iam using FME Desktop 2022.1.3
nielsgerrits
Not sure, but I have had my share of issues using the temppathnamecreator and I think the size has to do with it.
hkingsbury
Forum|alt.badge.img+73
  • Sep 18, 2023 2:31 AM UTC
Are you running with feature caching on? feature caching and the temppathnamecreator don't play nicely together
essb
  • Sep 18, 2023 7:22 AM UTC
Thanks for the tip, I tried without feature caching but same problem.
But I just solved the problem. They deliver the material as shape files aswell and that works.
