Can FME be used for secondary development in winfrom? There are secondary development tutorials
  • Aug 28, 2021 5:31 AM UTC
  • 37 views
  • Aug 30, 2021 7:59 AM UTC
What is "winfrom", do you perhaps mean .NET?
Generally speaking, there are two options:
FME Desktop: use the .NET (or, even better, the C++) API libraries, you'll find the documentation here <FMEHOME>\\fmeobjects\\dotnet\\apidoc
FME Server: use the rich REST API, documentation can be found here https://docs.safe.com/fme/html/FME_REST/apidoc/v3/
Out of the two I'd say that FME Server makes the most sense for "secondary development", if I'm understanding you correctly.
