CADRG Writer Performance
  • Nov 17, 2021 8:51 PM UTC
  • 0 replies
  • 46 views
vacalder
Participant
We are looking to decrease the total time converting from Geotiff tiles to CADRG. The bulk of the time is in the CADRG writer.
  • Are there any ways to process frames in parallel?
  • If we divided the region into smaller regions and created multiple CADRG output sets simultaneously could we then merge them together?
  • Are there any other parameters we could try settings to increase performance?
Processing a 300x300 nautical mile region takes around 6 hours using a TC map type. Is that normal given the size of the input region and requested map type (resolution)?
Thank you.
