Build line from non ordered point sequence
  • Mar 17, 2022 1:56 PM UTC
  • 53 views
boubcher
Forum|alt.badge.img+11
Hello there
we have a set of points getting to the line builder, not in sequence
how we could organize them to build them straight line
pointwe are getting this from the line builder
line builder 2I think the line builder is connecting the point in the order they enter the linebuilder
Any idea
thanks
geomancer
Forum|alt.badge.img+71
  • Mar 17, 2022 2:33 PM UTC
The LineBuilder does indeed connect the points in the order they enter (as is said in the documentation).
Would you like to create a 'best fitting' straight line? Or maybe sort the points first in ascending X and ascending Y, before they enter the LineBuilder?
boubcher
  • Mar 17, 2022 3:13 PM UTC
@geomancer​  thanks Great approch
danminneyatsaf
Forum|alt.badge.img+13
Hi @boubcher​, if the points you are trying to connect have an attribute that defines the order of the points, you can use a Sorter to sort the points by that attribute before connecting them to the LineBuilder.
