Best Practice to publish workbench to FME Server
  • Feb 17, 2023 7:26 PM UTC
  • 53 views
mvickers
Participant
Forum|alt.badge.img+5
When publishing a workbench to FME Server under my username and configuring it as an automation or schedule, what is the best practice as every time my username requires a password change the automations/schedules fail. Then one has to go in and modify the connections to update them so it will accept the new password. We are using AzureAD.
hkingsbury
Forum|alt.badge.img+73
  • Feb 19, 2023 7:36 PM UTC
For connections, best practice would be to use a service level account that doesn't have password a password expiry. This will then also remove duplication of connections and provide a clearer view of all connections for the administrator(s).
For publishing, you should be fine publishing with an account has a password expiry
