BADNEWS: Module 'TFS_VARIABLESCHEMA' is unavailable for use with this FME edition
  • Aug 23, 2021 10:51 PM UTC
  • 43 views
I am running a test workspaces closely derived from offset_reproject_vector test workspace in the FME Desktop 2021.1 SDK (this file is located in C:\\Program Files\\FME\\pluginbuilder\\samples\\cpp\\test).
When I run it in FME this error is displayed:
BADNEWS: Module 'TFS_VARIABLESCHEMA' is unavailable for use with this FME edition.
The derived test workspace is in the same test folder as the offset_project_vector test project.
How do I resolve this?
daveatsafe
Forum|alt.badge.img+24
  • Sep 15, 2021 10:26 PM UTC
Hi @raymond_wilson​,
BADNEWS messages are generally used for debugging by developers, and are not necessarily a problem the user needs to worry about. Please turn off debug logging in Tools - FME Options - Translation - Log Message Filter, then try the workspace again. If there is a problem, it will still be logged.
