autocad release drawing problem.
  • Sep 1, 2020 5:53 PM UTC
  • 50 views
gisbradokla
Forum|alt.badge.img+27
Why do i get this message on autocad files that are on our network?
AutoCAD Reader: Unknown or unsupported version of AutoCAD file ')#¾„ál'. Most recent supported version is ')#1032', which is also known as 'Release2018'
Is this saying that Safe does not support 2020?
daraghatsafe
Hi @Brad Nesom​
What build of FME are you using? Are the AutoCAD DWGs 2020? Do you experience the same behavior using the different AutoCAD Readers?
Thanks, Daragh
gisbradokla
  • Sep 2, 2020 12:49 PM UTC
Hi @Brad Nesom​
Thanks, Daragh
FME(R) 2020.1.0.0 (20200707 - Build 20594 - WIN64) i haven't created an output for the fatal. so i have done anything to determine their version. Also have not rebuilt my wb to try different readers.
