Attribute Manager changing \\ to /
  • Jun 4, 2021 9:00 AM UTC
  • 37 views
bubblebeb
I have used an Attribute Manager to create a new attribute for a file path.
The path is for example c:\\FME\\data\\myworspace\\sourcefile.html
The output from the Attribute Manager is c:\\FME\\data/myworkspace\\sourcefile.html
It is outputting a random / in the middle of the path rather than \\.
This results in the path failing to work.
I can use a string replacer after to correct it but it is not working correctly.
Any ideas on why it does this would be great.
Forum|alt.badge.img+54
  • Jun 4, 2021 9:29 AM UTC
Are you creating the file path from an existing attribute?
bubblebeb
  • Jun 4, 2021 10:24 AM UTC
Partially yes. I am basically doing this
c:\\FME\\data\\myworkspace\\@Value(User) sourcefile.html
