attiribut copy
  • Mar 20, 2023 11:37 AM UTC
  • 25 views
bayram
Forum|alt.badge.img+7
Hello
I want it to print an attribute data in the 1st point to the area specified in the 2nd data, can you support me?
The distance between two vertices is 6 meters
Not:Sorry I don't have a common column for join
hermann
Forum|alt.badge.img+11
  • Mar 20, 2023 1:20 PM UTC
If you want to join objects with no common attribute - it could be possible to join on position - e.g. use the bufferer and the clipper afterwards, which can merge attributes.
