AreaGapAndOverlapCleaner creates gaps
  • May 16, 2022 7:20 AM UTC
  • 201 views
I have a question regarding the AreaGapAndOverlapCleaner and I dont know how to solve my problem...
I have multiple polygon layer which I want to overlay. The lines of the polygons are not totally coincident as different data sources are used. Many sliver polygons are created when the layers are overlayed. I would like to remove these small sliver polygons with the AreaGapAndOverlap Cleaner (it does it job well - I used a tolerance of 1 m). My only problem is, that the AreaGapAndOverlapCleaner itself creates some little gaps between the polygons. Is there a way to prevent the transformer from doing it?
Using Fill All Gaps does not make sense in this case, as there are some big gaps (exclaves) that I want to keep.
Do you have any idea to prevent the AreaGapAndOverlapCleaner from creating gaps? Or is there any other transformer which suits better?
Thank you!
Forum|alt.badge.img+63
Do you have a screenshot you can share?
  • May 17, 2022 10:28 AM UTC
After_AreaGapAndOverlapCleanerBefore_AreaGapAndOverlapCleanerAreaGapAndOverlapCleanerFME_Workflow
  • May 17, 2022 10:29 AM UTC
In my latest answer, the first screenshot is a part of "Dataset_AfterAreaGapandOverlapCleaner", the second screenshot is the one before. After this the settings for the transformer "AreaGapAndOverlapCleaner" and the Part of the Workflow.
DanAtSafe
Forum|alt.badge.img+23
  • May 18, 2022 11:04 PM UTC
Hi @pelle123​ Are those line segments shorter than your tolerance of 1? The AreaGapAndOverlapClearner shouldn't be making holes. Can you send us some sample data via https://community.safe.com/s/submit-case ? Thanks
