arc Sec into degrees
  • Feb 2, 2021 9:33 PM UTC
  • 95 views
Guys, seeing al the magic u do... impressive.
This is only very start for me... any tips how to convert arc seconds into degrees...
thanks
tomf
Forum|alt.badge.img+31
  • Feb 2, 2021 11:50 PM UTC
Hi @joolek.o​,
Welcome to the FME Community!
To convert arcseconds to degrees you can use an ExpressionEvaluator transformer and use the expression in the screenshot below. Here the arcseconds value is held in an attribute named "ArcSeconds" and will create a new attribute named "Degrees" (just type that into the "New Attribute" parameter box)arcsec_Deg
  • Feb 3, 2021 12:53 AM UTC
Hi @joolek.o​,
wow! FME community is just... who r u guys :) I mean I've heard u r kind and helpful but experiencing it.. :) will give a go in the morning!! Thank you
