Anyone know how you excte the Ersi Submitjob in sysytermcaller
  • Feb 9, 2023 3:53 PM UTC
  • 51 views
asadamjad
Participant
Forum|alt.badge.img+12
I am using Systemcaller to send the request and getting error
Thi is the code where i need to exxucte
GET
https://maps.earlyalert.com/server/rest/services/System/SpatialAnalysisTools/GPServer/OverlayLayers/submitJob?inputLayer={"url":"https://maps.earlyalert.com/server/rest/services/Hosted/Master_Client_Areas/FeatureServer/0","filter":"clientid=283"}&overlayLayer={"url":"https://maps.earlyalert.com/server/rest/services/Hosted/Power_Outages/FeatureServer/0"}&overlayType=Intersect&snapToInput=false&outputType=Input&tolerance=null&outputName=&context=&context=&env:outSR=&env:processSR=&returnZ=false&returnM=false&returnTrueCurves=false&f=pjson
Forum|alt.badge.img+63
The SystemCaller is for calling an executable on your local system, since this is a URL, try the HTTPCaller instead.
asadamjad
Participant
  • Participant
  • Feb 9, 2023 4:20 PM UTC
getting error
Yes, so set the HTTP Method of the HTTPCaller to GET and the Request URL to the actual URL.
You may need to separate the actual request in the query string parameters, I am not familiar with this particular API but it should be mentioned in the API documentation.
I just pasted the url in the browser and it appears you also need a token to access it. Again, that should be in the API documentation.
