Another person having the ArcPro compatibility isssue.
  • Jan 4, 2022 9:55 PM UTC
  • 5 replies
  • 68 views
meinertk
Participant
 I have the following installed:
ArcPro 2.7.4
ArcGISDesktop 10.8.1
Background Geoprocessing 10.8.1
FME 2021.2.1.0 (20211203 - Build 21797 - WIN64)
I also have a workbench that used to work. It simply took a couple of old-school Esri SDE features plus two new-school features that have attribute rules applied on them, and therefore need ArcPro Translation turned on, which it is, and exported them to a file geodatabase. What used to work now gives me the dreaded "Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility setting. This 64-bit version of FME requires ArcGIS Desktop along with 64-bit Background Geoprocessing; ArcGIS Pro; or ArcGIS Enterprise" error. What else do I need to look for?
http://fme.ly/qua
meinertk
Participant
  • Participant
  • Jan 7, 2022 1:57 PM UTC
Unfortunately I'm still getting the same error.
nielsgerrits
Forum|alt.badge.img+67
Have you recently opened ArcGIS Pro? Every now and then you need to log in again.
meinertk
Participant
  • Participant
  • Jan 7, 2022 3:58 PM UTC
I thought of that, but I'm in it all the time. I'm starting to wonder if our IT dept is to blame, they've been doing a lot of security shenanigans to try and lock things down tighter. I have an AWS workspace that's outside of their realm, I'm going to try it there and see if I get the same results. BRB...
meinertk
Participant
  • Participant
  • Jan 7, 2022 4:20 PM UTC
So hey, guess what. It works on my AWS workspace, which is in our cloud, not our organization network. What do I tell our IT staff about what they need to let me do? What is FME doing when it's looking for an ArcPro license? We use a license server rather than AGOL for our ArcPro licenses, but the end result is that it's going on the interwebs I assume to see if the license is valid?
meinertk
Participant
  • Participant
  • Jan 7, 2022 4:30 PM UTC
As I think about this some more... FME is getting a license from the exact same License Manager, as is any workbench that deals strictly with "ArcMap" features, which still works. What is different about ArcPro licensing on a License Manager than everything else?
