AnchoredSnapper filter contain face
  • Jan 1, 2022 3:29 AM UTC
  • 80 views
charry
Forum|alt.badge.img+5
Hello, happy new year!
I meet an issue with the AnchoredSnapper converter. I use the AnchoredSnapper and SpatialFilter converters can't correctly filter the containment relationship between the two cad layer faces. Can anyone help, thanks
I uploaded my CAD data, JMD and JZD layer, I want to get JZD contain layer of JMD
Best answer by caracadrian
This is how I usually do this:
I buffer the features to be contained by a very small negative value, then send every thing to SpatialFilter.
In order to preserve the original geometry of the feature I put it in an attribute before buffering via GeometryExtractor and use GeometryReplacer after SpatialFilter.
If you snap features they won't contain each other, they will be touching. That is why I buffer whit a negative value.
Filter with Contains
caracadrian
Forum|alt.badge.img+23
  • Jan 2, 2022 1:22 PM UTC
charry
  • Jan 4, 2022 5:37 AM UTC
thanks,I try it
