Adding an Attribute for a Range of Records
  • Oct 25, 2019 5:27 PM UTC
  • 67 views
I want to create a new attribute value(CoolAttribute) for every record falling within Green to Red range. Green and Red appear consistently in the spreadsheet and Green is always followed by Red. Please refer to the screenshot below. I would appreciate your help.
Cheers.
Forum|alt.badge.img+54
  • Oct 25, 2019 5:57 PM UTC
You can do this in an attributecreator using adjacent attribute handling
First use an attributecreator to create a blank attribute, then use a second attribute creator, turn adjacent feature handling on and choose 1 prior feature and then you can set attribute values depending on the value of adjacent features
adjattribute.fmwt
  • Oct 25, 2019 6:39 PM UTC
adjattribute.fmwt
This works great! Thank you very much.
