about change the deault storage location
  • Feb 15, 2022 1:03 AM UTC
  • 34 views
Hello, i'm new to FEM. ​ I have a problem about changing the storage locationimageWhen the software FME Date Inspector reads the data, the data appear to be temporarily stored in this file. Is it possible to change this path?I have not much space on my c drive, and i got a very huge data, for the remaining space of my c drive, it is not enough to support the software to read this data
Forum|alt.badge.img+63
Yes, you can use an environment variable to determine where FME stores its temporary data: https://community.safe.com/s/article/fme-temp-environment-variable
  • Feb 15, 2022 4:58 PM UTC
it helps. Thanks a lot.​
