3D MultiArea features from FGBD (open api) - look mental in ESRI
  • Apr 14, 2021 6:19 AM UTC
  • 38 views
itsmatt
Forum|alt.badge.img+48
Hi all, I'm trying to output some 3D data to FileGeodatabase in order to view in ArcPro. I don't want to use the ESRI writer because we are using FME Cloud and the ESRI writer doesn't work on Linux. I also don't want to use I3S. It must be FileGeodatabase.
Anyway the issue I have is that the output MultiArea features get messed up when looking in ArcPro.
FileGeoDatabaseShape Multipatch looks fine but isn't possible with the API version of the FileGeodatabase writer.
When running though a GeometryValidator in FME I get a lot of Self-Intersection in 2D - but that is expected given these are 3D features.
Perhaps I'm missing something. Does is make sense to create MultiAreas here?
hkingsbury
Forum|alt.badge.img+73
  • Apr 14, 2021 8:01 PM UTC
Yikes, i've seen something similar when uploading to AGOL/Portal, but not in Pro. Can you share the data? or at least one part of it? (building?)
