3B georeferans
  • Oct 17, 2023 8:11 AM UTC
  • 10 replies
  • 97 views
bayram
Forum|alt.badge.img+7
3dHello, I have 3D building data in 3ds and sketch formats. These data are not georeferenced. How can I move this data to the real place? I tried offsetter, but it did not work. Can you help me? I will do scal and rotate later.
nielsgerrits
Forum|alt.badge.img+67
Can you explain what went wrong? How did you check the result? Did you assign a coordinate system after the offset? What are the drawing units? You probably also have to scale if the drawing units are in bananas or mm.
There are multiple ways to reference data from local to real world coordinates.
  • Manually
    • Offsetter
    • Scaler
    • Rotator
  • Semi automatic
    • Affiner
      • Calculate coefficients for offset / scale / rotation.
  • Automatic
    • AffineWarper
      • Use from-to lines as input.
Depending on how much models and how complex I would either do this using the Offsetter, Scaler & Rotator or the AffineWarper. If using the Affiner, I Iwould use individual transformers for offset, scale and rotation.
bayram
  • Oct 18, 2023 8:47 AM UTC
  • Manually
    • Offsetter
    • Scaler
    • Rotator
  • Semi automatic
    • Affiner
  • Automatic
    • AffineWarper
Hello, thank you very much for your return. I get a very long list of errors3b
bayram
  • Oct 18, 2023 8:48 AM UTC
3b2
bayram
  • Oct 18, 2023 8:49 AM UTC
3b1
nielsgerrits
Are these errors caused by the Offsetter or the PROJReprojector?
I think I would use a CoordinateSystemSetter, not a reprojector, because there is no source CRS.
bayram
  • Oct 18, 2023 9:12 AM UTC
If you have time, could you help me if I send you my file?
nielsgerrits
I can try a bit, but my experience with 3d and FME is limited.
bayram
  • Oct 19, 2023 6:03 AM UTC
Hello Nielsgerrits
Have you been able to see if there has been any progress?
nielsgerrits
I tried but no luck and ran out of time.
bayram
  • Oct 19, 2023 6:14 AM UTC
I understand, thank you very much for your time. :)
