Reading a tsv file
  • 5 September 2024
  • 24 views
Hello there,
How can I read a tsv file in FME? Do we need  to use csv format only:?
Thanks,
Siva
Yes, you can use the CSV format and just change the delimiter in the parameters dialog.
There’s also a CAT (Column Aligned Text) format too, if the contents are aligned like that.
Thanks very much for your prompt reply
