Hello,
I’m using HTTPCaller to retrieve a set of data via an API that I know works, as I tested it in Postman. The problem with HTTPCaller is that the response_body is not as full as what I received in Postman (I don’t have the full result), so I cannot continue with my process.
I don't know if anyone can help?
Thanks!
Unfortunately you haven’t really provided much information for us to go on.
Can you provide some screenshots/examples of what you’re getting out of postman and FME, and the configuration of both the HTTPCaller and postman? Make sure you cover any tokens or passwords
