Hi there, I am a new user so this may be a newbie error.
I have just tried to install FME on my Ubuntu Workstation. It is running the latest version, 24.10.  The latest version that FME lists has is
fme-form-2024_2024.1.3.24627~ubuntu.22.04_amd64.deb
so I downloaded that.  It fails to install with a long list of failed dependencies. Is this install going to be possible?
TIA.
Kerry
Hi @alfasud You’ll get a long list of failed dependencies the first time you install FME on Ubuntu.  Just run
sudo apt-get install -f
to fix any dependency issues.
Done that but I’m still getting the same list of unsatisfied dependencies.
Unsatisfied dependencies:
 fme-form-2024 : Depends: libboost-chrono1.74.0 (>= 1.74.0) but it is not installable
                 Depends: libboost-filesystem1.74.0 (>= 1.74.0) but it is not installable
                 Depends: libboost-iostreams1.74.0 (>= 1.74.0) but it is not installable
                 Depends: libboost-locale1.74.0 (>= 1.74.0) but it is not installable
                 Depends: libboost-regex1.74.0-icu70 but it is not installable
                 Depends: libboost-thread1.74.0 (>= 1.74.0) but it is not installable
                 Depends: libcfitsio9 (>= 3.480~) but it is not installable
                 Depends: libdraco4 (>= 1.5.2+dfsg) but it is not installable
                 Depends: libicu70 (>= 70.1-1~) but it is not installable
                 Depends: liblerc3 (>= 3.0) but it is not installable
                 Depends: libpython3.10 (>= 3.10.0) but it is not installable
                 Depends: libtbb2 (>= 2018~U6) but it is not installable
                 Depends: libtiff5 (>= 4.0.3) but it is not installable
Error: Unable to correct problems, you have held broken packages.
libboost-chrono is not a package but libboost-chrono-dev exists and installs a version of libboost-chrono >1.74 but that makes no difference to this error.
Sorry, I just noticed that you’re using the installer for Ubuntu 22.04 .  Try https://downloads.safe.com/fme/2024/ubu_24/fme-form-2024_2024.1.3.24627~ubuntu.24.04_amd64.deb instead.
Better, but not there yet:
 fme-form-2024 : Depends: libboost-chrono1.74.0t64 (>= 1.74.0+ds1) but it is not installable
                 Depends: libboost-filesystem1.74.0 (>= 1.74.0+ds1) but it is not installable
                 Depends: libboost-iostreams1.74.0 (>= 1.74.0+ds1) but it is not installable
                 Depends: libboost-locale1.74.0 (>= 1.74.0+ds1) but it is not installable
                 Depends: libboost-regex1.74.0-icu74 but it is not installable
                 Depends: libboost-thread1.74.0 (>= 1.74.0+ds1) but it is not installable
So I take it this is because I’m using 24.10 and there isn’t an installer for this version yet?
Yes, FME only supports LTS releases every 2 years - 20.04, 22.04, 24.04, 26.04… If you can’t reinstall 24.04 then we recommend using a Docker or a virtual machine.
Oh well, I can’t get a trial license anyway so I think this is where I give up.
Hi Kerry,  Did you apply for the Platform Evaluation license at https://fme.safe.com/pricing/charitable-licenses/ ?
I did find that - funny place to be, on the Charitable licences - but I did apply.  I think they tried to refer it to a partner?
 It is not clear where to go next - I realise here is not the right place!
This should be the right place. Did you click on Platform Evaluation Program, then
Apply Now
Tell Us About Yourself
About Your Organization
Purpose of License
