Hi everyone,
We have floating licenses and installed FME Form in a server, and the users will login to that server to use FME. So, my question is How many users can run the same workspace using FME Form in a same server at the same time?
My user has different username and password to access the server.
Please advise.
Thank you.
Assuming they are not writing to the same files, it should be however many floating licenses you have. You will need to be cognisant of the log files though.
It also depends on your Windows licensing, by default you can only have a maximum of 2 concurrent RDP sessions. You can extend that by purchasing Remote Desktop Client Access Licenses
Got it, thanks everyone!
