Currently we are using FME work bench to connect to S/4 via OData, however there are performance issues with using Odata, Is there any threshold limit uptil which FME can support the data extract using Odata without any performance issue. Any document or any recommendation from SAFE.
What are the other options to connect to S/4 Rise if we do not want to use OData, our FME will be in AWS .What all config options we have other than OData to get rid of the performance issues. If at all there are other options available what all are the components needed to have the same
Please help urgent
Be the first to reply!
