Hi Folks,
I have previously installed and worked on FME Server, with my last usage being approximately 2–3 months ago.
However, I am currently unable to log in, and the system displays the following error message:
Could someone please assist in identifying the cause of this issue and guide me on resolving it?
Thank you in advance for your support.
I assume that Troubleshooting help link refers to the FME Flow Troubleshooting guide.
So, just to clarify: do you see the login page and do you get that error when you try to log in?
Hi ​@redgeographics
Yes I see the login page. When I enter the usename and password, after that this error appears.
I can’t really see anything in the guide that looks like this. What I would try is:
  • Make sure all FME Flow services are running
  • Try it with a different browser, or in incognito mode
If neither work it’s probably best to file a support case with your local partner or Safe.
