I am clipping a raster and then running RasterStatisticsCalculator. The results are completely wrong to what I get in ESRI using zonal statistics and the only stat that is correct is the max value.
FME Results:
When I export the raster and bring it into ESRI, cell values are different and zonal stats are different
Zonal stats results from ESRI:
I would appreciate some help in how best to run zonal stats in FME.
Thanks,
K
