I am just in the process of migration testing from FME Flow/Form 2023.1 to 2024.1. It seems all of our GeoDB dynamic writer fails the following error:
Esri Geodatabase Writer: Feature Type Definition 'd_y_n' was requested, but not defined. Please visit https://www.safe.com/support
All existing runs perfect on 2023.1 Flow and Form - not sure why it fails. Tried all possible scenarios, still fails. I have changed it to a normal writer - then it worked fine.
GeoDatabase - SQL Server 2017, SDE Version 10.9.1 (pro 2.9 created)
Pro Version 3.3.1 installed on PC / Server
Rudy
Hi @rudy_v, it sounds like it may be an issue with the schema feature. This question may help:
If it doesn’t, I suggest submitting a support ticket so that a member of the FME Form team can investigate further.
https://support.safe.com/hc/en-us/p/Support
Hi @mattmatsafe
I tried all the possible ways - but I have recreate the FMW workspace from scratch - and it seems to work now. Not sure why it did not work by just loading the 2023.1.3 version
Rudy
