Hi there,
Has anyone found a solution to FME Hub connection in Version 2021?
Hi there,
I have never used this functionality but I can reproduce this in 2021. If you really want to you probably can create a ticket at Safe, but I doubt they will fix it as 2021 is nearing end of support? There are alternatives:
Thank you so much for your reply
